    Page 7 of 16 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
    Results 121 to 140 of 301
    1. #121
      Sep 2007
      Southern California
      That is one sweet looking motor!
      Jon
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
    2. #122
      Dayton Ohio
      Quote Originally Posted by Roadbuster
      Jon
      thanks
    3. #123
      Sep 2007
      Southern California
      With those E heads do you need to use RAIV headers?
      I thought that is what was required. The thing that puzzles me is the flat bottom of the port and how does that transition to the round header. That is the first shot I have seen of the E head exhaust ports.
      Jon
      Jon U.
      Build Thread
    4. #124
      The rally wheels sure make a big difference! Good job! Awesome car. Bad to the bone motor!
    5. #125
      Feb 2006
      You do have to use RAIV (round port) headers with the e-heads. The flat bottom on the ports is like that because it makes the exhaust port flow better. It also creates a sort vortex area just outside the exhaust port that help prevent reversion of exhaust gases that can pollute the intake charge. An old trick for ford 302 boss and 351 C engines was to install port plates in between the heads and headers to create this "D" shape. They say it helped alot on those engines too.
    6. #126
      Dayton Ohio
      yup have to use round port
      Since I was in Akron this weekend I stopped at Summit Racing and picked up a set of Doug's headers
    7. #127
      Oct 2007
      Southern California
      Hey that engine is coming along nice! are you going to dyno it?
    8. #128
      Dayton Ohio
      Quote Originally Posted by BaddestBuick
      eventually
    9. #129
      Dayton Ohio
      mmmm headers Doug's Headers to be exact. Picked them up at Summit Racing while I was up there this past weekend
    10. #130
      Apr 2007
      Utah
      Nice looking work on the engine.
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
    11. #131
      dayton, oh
      sweeeeet
      dave.t
      74 Javelin AMX - stocker
    12. #132
      Sep 2007
      Southern California
      Quote Originally Posted by gearbanger
      Thanks for the technical explanation! Before I saw the pic of the ports I thought they looked like RAIV ports.
      Jon
      Jon U.
      Build Thread
    13. #133
      Thats interesting on the Boss motors ,I didn't know that. Engine looks good.
    14. #134
      Dayton Ohio
      brought the headers by the shop for a test fit and also checked out the new intake manifold
      still waiting on the valley pan and crank pulley
      old water pump piece
      you can see the crack in the pulley
      valley pan speaks for itself
      455 the shop is building for another customer
    15. #135
      Dayton Ohio
      stopped in to check on my brothers 305 block the shop is cleanign up for him and I decided to bring one of my new valve covers in to see how it looks
      lets just say I huge a huge boner after seeing it hehe
      also the shops Roadrunner with a new Super Charged Hemi they fabbed up their own manifold for the supercharger to sit on.
    16. #136
      Dayton Ohio
      grrr
      called butler performance yesterday and they are still waiting on the shipment of valley pans to come in
      I'm really wanting to bring this engine home
    17. #137
      Feb 2006
      On that water pump, you should put the plate against the pump and check the clearance between the impellar and the plate at the center hole. The clearance should be minimized in order to keep the efficiency of the impellar. Alot of times it is 1/8" or more with aftermarket parts and that can be the root of hot running problems with pontiacs. I just wanted to let you know while you have it apart to check it. You may have already known this.
    18. #138
      Dayton Ohio
      thanks I noticed that int he pontiac engine building book today actually but the shop has already assembled the water pump we will see what happens plus I want to switch housings down the road tot he butler performance one like on the 455 I pictured there
    19. #139
      Feb 2006
      You should be okay, but if you have hot running problems that is the first place to look. You should check out KREpower.com and look at the timing cover they sell. It looks pretty cool.
    20. #140
      Dayton Ohio
      looks good
