      Apr 2007
      SK-Canada
      Looking for How-To for posi install
      I've been having some issues with the open rear diff in my truck so I'm planning to fix that issue and upgrade to a posi unit at the same time. I'm trying to find out wether or not this is the type of project I could tackle on my own and I thought reading a How-to article would give me a good idea of what's involved. Do any of you have a link to one that's fairly comprehensive? I'm hoping there aren't too many brand specific tricks, but just in case it matters I'll likely be using a Moser eaton posi unit.
      -Evan
      1980 Chevy Malibu 4dr
      1978 Chevy c10
      2004 Suzuki SV650
      CHICAGO SUBURBS
      You'd have to set up the gear pattern on the ring and pinion if you change the carrier. You'd need some specialized tools or a lot of trial and error to get it right. You could try one of the Lok Right kind of units that change only your spider gears. There are two kinds of those, one is quiet and one is clunky and noisy. Those are easy to install with normal hand tools.
      May 2002
      Northern California
      It isn't too difficult to learn. I caught on after watching my neigbor build his 12 bolt at the age of 13.
      You do need special tools and you should have a manual to get specs from. If you are going to do this alot it would be worth it to buy the special tools required. But then again most shops will charge 2-3 hours for a carrier swap.
      Hardest part is to get the proper pinion depth. They make a tool to help you set that up.
      Here are a few on line guides from a quick google search.
      http://www.drivetrain.com/ringpinioninstal.html
      http://www.differentials.com/install.html
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Apr 2007
      SK-Canada
      I was thinking about getting a shop to do it but I have never been able to find one that actually takes this much care.
      Preparing Parts
      Clean all new and used parts with clean solvent. Dry the parts. De-burr the back of the ring gear and carrier mounting surface with a file or wet stone. Wash out the housing with solvent and check all of the oil passages for metal particles or dirt that can lead to early wear. Many housings have oil passages to the pinion and grooves just outside of the carrier bearings. Push rags through the axle tubes, using solvent or brake cleaner until they are clean. Polish all seal surfaces with light emery cloth or fine sandpaper and then wipe them with a clean rag and clean oil or solvent to remove metal particles. Use a moderate coat of gear oil (not grease!) on all bearings and grease (not oil) on all seals and seal surfaces just prior to installation.
      Every time I get someone else to do something for me I'm disappointed by the amount of care that is taken. Nobody ever takes the time to actually clean the parts that are being reused.
      ...but I guess finding a good shop is a different topic all together!
      -Evan
      1978 Chevy c10
      2004 Suzuki SV650
      Dublin, CA
      Quote Originally Posted by evan
      It is really a time issue with the shops. Cleaning the differential takes a bit of work and you would pay the additional shop hours.
      I was going to do my gear change, and had all but the torque bar for the pinon nut on hand, but decided to go ahead and have a local shop set the gears. Good thing too, turns out my carrier and yoke where both shot; most likely, I would not have caught that. In the end it was still under $200 to have the gears set and bad parts replaced. Now, I did bring them the gears, bearings and cleaned the differential inside and out before taking it in. I also installed the Powertrax locker when I got it back to the house.
      In the end I know I could have done it, but it would have taken a lot longer and I may have needed a few extra crush washers to get it right. If you can find a good shop, I would say for the money let them do the gears.
      Brent
