    Results 1 to 9 of 9
      Apr 2007
      SK-Canada
      way to estimate rear diff ratio?
      Is there a way to figure out pretty accurately what gear ratio a rear end has based on counting tire and driveshaft revolutions? I just counted on my truck and in 10 revolutions of the tire the driveshaft made 17 revolutions.
      -Evan
      1980 Chevy Malibu 4dr
      1978 Chevy c10
      2004 Suzuki SV650
      St.Anne Il
      they say rotate it once and multiply the number of times the drive shaft rotates times 2...so you say your drive shaft rotated 1.7 x 2 = 3.40 thats just a rough guess way..thats what i found out googling it..lol
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Apr 2007
      SK-Canada
      Cool. So I probably have 3.43's.
      -Evan
      1978 Chevy c10
      2004 Suzuki SV650
      Dec 2002
      Lost Wages, Nevada
      Turn both rear tire at the same time (if not a posi it might take two people)...
      Count the revolutions of the drive shaft per one turn of the tire.
      If it goes 3 and 3/4 turns... its 3.73's. If it goes a little over 4 turns... its 4.10. You get the idea...
      Or just take the cover off. The ratio is stamped on the ring gear. You will see something like 41 10. 41 teeth on the ring gear, 10 on the pinion, hence 4.10s.
      Feb 2007
      tire height x rpm x 0.002975 / speed = rear end ratio.
      Winchester, VA
      Quote Originally Posted by chicane67
      That's the easiest way I've found. Been doing it that way for long time. Clean and quick, it only takes a couple of minutes. Might need a marker or chalk to mark on the tire and the driveshaft. I always mark the tire at the bottom, mark the driveshaft at a spot you can see easily, roll the car until the tire mark makes one revolution while counting the driveshaft revolutions. One tire revolution, about 2 3/4 rotations = 2.73 (my first rear). I installed another rear with 4.10's, tried it again for proof that it works, and driveshaft spun just over 4 times = 4.10.
      Wayne Smith
      '70 Camaro - 406 - Street/Strip being converted to Pro-Touring (best 1/4 run - 11.05 @ 121, 1.50 60' - NA)
      '47 Chevy truck - 250 L6 / 5 spd - Resto Rod/Work Truck in the works
      Winchester, VA
      Quote Originally Posted by Adam's 55 Chevy
      That might work with a stick, but not so well with a high stall converter due to slippage variances.
      Wayne Smith
      Aug 2006
      Taunton, Ma.
      Wallace Racing has more calculators for stuff like this than you could throw a stick at. Check it out.
      John
      "There are no stupid questions, but there are a lot of inquisitive idiots!"
