    Results 1 to 20 of 21
    Thread: Visqueen???
      Miami
      Visqueen???
      I am looking for the white "plastic wrapping" that comes on new car hoods and fenders from the factory...I believe it's called Visqueen...
      Anyone know where I can get a roll or two of it?
      St.Anne Il
      are you looking for it to be sticky? or just plastic..cause any lumber yards will have it they use it to put under concrete for a vapor barrier..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Miami
      needs to be sticky...I want it to wrap some fenders and a hood for storage....
      Fond Du Lac,Wisconsin
      I looked who makes it for us its called company name Unisource
      you can get it in differant sizes for a roll 8in wide by 325 ft long with 10in perf B&W film Part number 10100675 $21.64 per roll
      1-800-864-7687 Give them a call they will help you
      Miami
      Thank you...Is it the sticky type I hope? or will they be able to answer that?????
      Call some boat storage places, shops also use that suff on boats for Winter.
      Feb 2006
      Somewhere in the Pacific Ocean
      Another alternative would be to use stretch wrap like they use on stuff that are shipped on pallets. Just wrap it all around the hood etc. You can find those at places that sell shipping & packing supplies usually.
      Miami
      Quote Originally Posted by 7TSS
      yeah I have that at work..so I can borrow a roll or two....
      I used this stuff one time to draw out a flame pattern on a car....made it very easy...
      Apr 2002
      Quote Originally Posted by Kustom_dude
      Not the same stuff. Shrink wrap is a thicker material and has no adhesive.
      --JMarsa
      Newbury Park, CA
      Quote Originally Posted by jy211
      There are types that have a VCI on one side to help prevent corrosion formation. McMaster Carr carries it.
      If it is a steel component you may want to consider using LPS3 as a long-term rust inhibitor.
      Macon, Ga.
      Lowes, Home Depot, carpet installation stores, RV dealers, all have carpet protective plastic, called different things, but all have sticky side. I have a roll or two, but would not be worth shipping to you. Better to buy it locally.
      Bill
      Trailers are for BOATS!
      CHICAGO SUBURBS
      They have a similar kind of stuff at hardware stores and home centers for carpet protection. Sticky on one side. Long term regular shink wrap might be better. The adhesive kind might stay stuck. Even the dealer stuff can be a bear to remove after a while.
      Macon, Ga.
      Quote Originally Posted by HILROD
      Goo-b-gone is the solution for that!
      Bill
      Jun 2006
      NW burbs IL
      Quote Originally Posted by Bill Howell
      Goo-b-gone
      Ga-zuntite!
      Matt
      Southern Indiana
      I would recomend NOT using anything like that as it may damage metal/paint,,,seen it do this.
      Best thing is a soft wrap, ina sealed bad with a pack of desicant in it.
      May 2002
      Northern California
      Im not sure what it is called but it goes on wet sheet and dries to the plastic like finish.
      this came up on the mirror covers....http://www.apfilms.com/
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jul 2007
      Visqueen is a plastic vapor barrier that is used in construction.It comes in all differant mill thicknesses from 1-10 mill. Why cant you use vinyl adhesive sheet. You know the stuff sign shops cut letters out of.
      Snohomish, Washington
      ya visqueen is not the right stuff to use, we use it to keep the water off dirt and keep the wood for the framers dry!
      Matt
      Lees Summit, Missouri
      www.strouse.com
      PN 5183895
      This is the stuff that GM uses to wrap their vehicles or put on the hood, trunk, wheels, etc.
      Later - Craig
      [email protected]
      '70 Chevelle (in storage now, probably will never be back on its wheels again!)
      Miami
      Quote Originally Posted by BADVELLE
      www.strouse.com
      PN 5183895
      Thanks!
