    Results 1 to 11 of 11
      Mobile, Al
      Timing problems with TPI L98... Help!
      I did a tuneup on an '87 Corvette L98. You know, plugs, wires, cap rotor, module, coil (HEI), and pick-up coil. It ran well before except for a little "surging" at idle. The #1 plug wire was in the wrong position on the cap when I took it out to replace the pick-up coil. So, I put it back in the right way after timing the engine to #1 cyl compression stroke. The first indication something wasn't right was the timing mark on the balancer was about 180 off. I even used a straw to be sure the piston was all the way up. And yes... definitely on the compression stroke. By the way, I 've worked as a heavy equipment mechanic for over 15 years and have built many engines in the garage so this type of work is nothing new to me.
      Anyway, the engine sort of "kicks back" while cranking, it even broke the starter bendix. When it does crank it idles and revs good and smooth unless you try to "pop" the throttle. Then it stumbles a little then revs OK. I can't get the base timing down out of the TWENTIES and it run descent. I do have the tan elec. timing advance wire behind the distr. unplugged.
      This Vette has about 120K on i. These distributor parts came from O'Reilly Auto Parts... they are the lifetime stuff. Do you think it could be the aftermarket mobule and coil? Any suggestions? Thanks
