Thread: Scratch on cylinder wall
10-13-2007 #1
Theres a minor scratch vertically, not to deep but deep enough where you can feel it if you slide your hand around the wall youd notice it. Its down at the bottom of the cylinder wall and i was wondering if i can use a hone to get rid of it without needing to bore it over? Its already .030 now and im trying to save a trip to machinest. Should i just hone it out and use one of the old rings and check the gap on it?
Another question, Total Seal makes A moly ring kit for 4.035 bore. Can i hone out the 4.030 to 4.035 to fit the Total Seal rings if need?
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
10-13-2007 #2
- May 2006
- 115
if the cylinder is not oval.. (measure to check) a hone should be just fine...
10-13-2007 #3Its not oval, its still a perfect circle.
But thanks
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
10-13-2007 #4
Starting The Transformation
- Sep 2004
- 135
Go w/ it!!
Dingle-berry hone her!!
pdq67
10-13-2007 #5What grit blocks should i start out with and gradually move to when honing? And how would i finish the walls?
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
