    Page 2 of 2 FirstFirst 1 2
    Results 21 to 31 of 31
    1. #21
      Windham, NH
      Quote Originally Posted by Chad-1stGen
      Kinked doesn't make sense to me. A properly designed setup would use hoses that can withstand the maximum pressure the fuel pump can deliver. Otherwise that is poor engineering IMO. If the pump itself is capable of only delivering 76 psi then a kink shouldn't make it go higher than 76, it would just restrict flow at that point.
      Sounds like a defective hose IMO.
      So if you keep delivering 76 psi to the line with no outlet for the fuel (the pump keeps pumping), what happens? I am no mechanical engineer, but wouldn't line pressure increase (I am not saying the pump pumps more PSI) as the pump continues to pump? Or is there some sort of pressure valve?
      Phil
      Build site: www.73camarobuild.com
      Business: www.classiccarblasting.com
      Like us on Facebook!
    2. #22
      Monterey Peninsula
      Quote Originally Posted by Hidro
      Was the hose imported?....china?
      Glad its an easy fix.
      Whoops...better check the lead content.
      Seriously,that hose must be formed that way for a reason and I think that reason is strength.Musta been defective from the get-go...
      www.buickfunnycar.com
    3. #23
      Huntington Beach, CA
      Quote Originally Posted by 69TAPoser
      Phil
      At some point the pump will not be able to pump and I'd guess it's not at a significantly higher pressure than the rating and to use a line that will burst due to slightly higher PSI from something like a kink sounds foolish.
    4. #24
      Jul 2003
      Anaheim Hills, CA
      Fuel Safe called this morning.. they don't have a clue. They said the hose was teflon but it doesn't seem like any teflon I've ever seen. They are sending me new fittings and a retrofit hose. It's sort of a pain to adapt to the pump, but it should fix the problem.
      I asked if they could overnight the parts since the car needs to move. They said "No".. that the owner said he would not expidite the parts more than UPS ground even though it was clearly thier fault. I'm happy they are sending the parts but was a bit ticked that they wouldn't rush the parts considering the situation and the fact that the tank was nearly $2000. Their customer service score was a C+ on this. The Tech guy was great and did his part very well.
      I paid the charge to have the replacement parts overnighted.
      The hose sure seems wimpy in person. and the blown part looks melted but I think it just expanded like a balloon and popped. Maybe a defective hose. Anyways, should have it fixed tomorrow.
      1968 Track Rat Camaro:
    5. #25
      Jul 2001
      Detroit, Michigan
      Geez....that car just doesn't want to live, Steve. LOL!!!
      If this is what's happening to you, I can only imagine what's going to happen to my project before September. This is the kind of stuff that makes up the fabric of my life. EVERYTHING has come the hard way.
      Glad to see you're nearing the finish line though.
      Oh...and by the way...did you get my PM?
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
    6. #26
      Jul 2003
      Anaheim Hills, CA
      So they charged my $58 to ship the parts (To fix thier screw up) and they didn't send sufficient parts for a fix.
      They sent me the parts to convert the fuel pump to an 8AN exit and the corresponding size push lock hose. They sent me 2 feet of push lock hose...
      BUT they didn't send me a fitting for the top and it's a 6AN sized push lock fitting.
      Why didn't they just build the f'ing system with #8 the first time? Especially since I specifically asked for a #8 exit out the lid.
      We ended up getting the right Gates hose (for EFI) and attached it using two hose clamps. Later I will buy ANOTHER #8 90-degree push lock fitting and make the system how Fuel Safe should have built it in the first place.
      Big thanks to Tom (Chicayne) for calling me today with advice!
    7. #27
      Miamisburg, Oh
      Terrorists!
    8. #28
      Central California
      That EFI should be a recirculating system with a pressure regulator. Eighty-seven psi sounds very high for system pressures at the injectors.
      Agree about that hose not looking up to the task . . . I'm betting it was kinked and failed at the crimped area of the forced bend.
      Get 'er up and running soon, Steve . . .
      Mary Pozzi
      "STICK, you B*TCH!!!!!!"
    9. #29
      Henderson,NV
      Machines break and parts fail. I am sure Steve already has it whipped since Sema is 2.5 weeks away.
      Todd
    10. #30
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by mpozzi
      Mary Pozzi
      She's running great. The regulated pressure to the rails is 60psi. The pump puts out 79psi (200gph). The hose fail either due to a defective hose of the fact that Fuel Safe kinked it durring assembly. I wish they would have built it better to begin with. But that's hot rodding for ya!
      Quote Originally Posted by Vegas69
      Yea, we fixed it. Later we will fix it right by swapping the smaller internal line to a larger line (the way Fuel Safe should have done to begin with).
    11. #31
      Nov 2001
      Sacramento Ca
      Cool. Congratulations Steve. Now, make us another awesome burnout of triumph video! (or post the old burnout of anger one, now that the car is fixed.) LOL
      Tony Langlois
      1966 Corvair Monza
