      Oct 2006
      Norway
      SB Chevy 350 HP++
      A friend of mine want to buy a new engine for his -79. We have looked at the GM zz4 engine. Where is the best place to get this engine? Any other engines that we must concider?
      Olav
      Sep 2002
      San Jose, CA
      Olav
      What sort of budget do you have to work with? Does this car need to pass smog?
      Just call me Brett
      Oct 2006
      Norway
      Crate
      The smog test here in Norway will not be a problem. No CAT and the smog values are high on cars before -83.
      So this is not a problem. This is daily driver car and it must be safe and no reliable. I don't want to use my time wrenching on this car....
      Olav
      Sep 2002
      San Jose, CA
      For a fire-and-forget engine the ZZ4 is hard to beat. The only downsides are
      1) Hyperutecnic Pistons preclude the use of Nitrous or Turbo/Superchargers
      2) It is External Balanced (the original 350's were internal balance) so you will need the appropriate flexplate/flywheel
      3) It uses a poor quality plastic timing chain cover which is prone to leaking over time. But than again, its a small block chevy, its gonna leak oil no matter what.
      I like http://www.sdparts.com/ for suppliers of the GM stuff
      I would also give serious consideration to the ZZ/383 engine which has a longer stroke (3.80" vs 3.48") and superior heads
      Just call me Brett
      Oct 2006
      Norway
      I agree with the zz4, I will take a looka at the 383 also...
