    Thread: TPI vs TBI
      Monroe,N.C.
      TPI vs TBI
      Ok my question is this.
      Run a stock Tune Port 1990 350 TPI motor, or run a 1994 TBI setup. Both will have mild cams for either fuel system. Its going in a 84 C-10 SWB truck. Taking out the extra fuel hungry 383 in favor of some drivability with a little performance. I have access to either engine, just wanted to see what "ya'll" think.
      Aug 2005
      Patterson, NY
      TPI.
      I think I'd rather run a carb than TBI.
      TPI. If it's for a truck with a mild cam I'm assuming you won't be revving it too hard.
      Feb 2007
      I'm sure you can get the tpi to run at least a little better. But at least with throttle body injection you can actually watch and make sure the fuel is spraying out right, or isn't leaking when the engines shut off. I don't know how you would do that with tpi, could be more trouble.
      Sep 2007
      Stock TPI set up is designed for Torque. The extra Tq would be help move the mass of a truck. The TBI is ok too, a throttle body spacer helps increase fule atomization.
      I would definitely go with the TPI, more responsive on a truck with a broader torque curve.
      Peter J.
      67 Chevelle--Pro Touring to the max
      68 Charger-- Pro Rust to the max, but I still love her. Soon to be PT Charger!!
      65 Galaxie Vert--Work in progress!
      06 H2--10.3 MPG Daily Beater!
      The TPI motor powerband is great for a truck. They get reasonable fuel economy too. TBI - I agree with the earlier post - might as well use a carb.
      Jackson Ms
      i have a stock 92 trans am tpi (305) in my 85 LWB 1/2 ton chevy truck. if i were you i would run the tpi and leave it 100% stock. it will run better and pull harder. the only bad thing about TPI is the lack of aftermarket tuning. that makes things like cams and heads a pain to deal with.
      Chris V
      SOLD
