    Results 1 to 20 of 26
      Sep 2007
      Any Chevettes out there?
      As the title states.....I did a search but only came up with a few results. Pictures would be great! I got a 78 at a great price and am gonna have to....well.....ummm...upgrade it. I'd like to get some 17'' rims, lower it and some body mods. Anyone know the bolt pattern size? Or any link to chevette related sites?
      Please help
      NoVA
      I have a Che-velle with a Cor-vette motor...does that make it a Chevette?
      Eric
      '72 Full Ride Chevelle: LS7 power, Optima juice
      KY
      lol i would say hell yea
      i havent seen any sites for the real ones but hell i am sure that there is
      Southern Indiana
      OK turbo 4.3 v6, 6 speed, build either an 8 in Ford or an 8.8 and with all the parts around for Fox Mustangs you wont lack for parts.
      also get some air ride to let it slam at rest and a few very slick body mods.
      Good Luck
      Lee
      Sep 2007
      Pull it over!!!
      Fontana, CA
      How about a Citation?!
      Nick R.
      Sep 2007
      Any pics?
      I'm going to pick this thing up today....still can't believe I bought this.
      Fontana, CA
      Nick R.
      Sep 2007
      I"ve got a few ideas but nothing concrete....
      Heres a few renderings I did the last couple of days....some slight body mods.
      Salem, NH
      Kinda reminds me of a Ford Festiva I saw in Hotrod mag about 10-15 years ago. I think it had a 5.0 liter V8 and vette wheels.
      NoVA
      Is it RWD?
      Eric
      Sep 2007
      Yes
      Northern CA
      Ya' know... in your drawings it doesn't look half bad.
      Never trust a pretty girl... or a lonely midget.
      Jun 2006
      I know I'm constantly plugging this 500 Caddy engine all the time but....one cool mod would be to transplant a the motor/FWD trans from a 70-76 Eldorado and make it a Big Block mid-engine/rear-drive car.
      You could probably do the same thing with a wrecked 05-up Impala/Monte SS with the 303hp DOD V8. Great power and great fuel mileage.
      Gonna need a serious heat shield behind the front seats though!
      Nov 2001
      Sacramento Ca
      someone can draw! Nice! there's a few guys working on them.
      I did a photoshop job a LONG time ago on the subject.
      Tony Langlois
      1966 Corvair Monza
      Sep 2007
      It will soon be a two seater...hard to believe its even got a back seat!....the firewall will be reworked to allow for more room in the engine bay. The rear will be tubbed. I have a few different ideas for the engine.
      This is on a very limited budget. I don't know how much I really want to drop on this thing.
      Sep 2007
      Quote Originally Posted by hdesign
      Funny...I had thought about trying to find an engine/trans/cradle/subframe/suspension from a newer GM car, and make a frame that would allow the entire assembly to mount in the rear.
      The steering could be made to stay stright and radiator and gas tank could be up front.
      Jun 2006
      Well, Caddy motor/trans can be had for a song at a wrecking yard. They are relatively cheap to build compared to a BBC or BOP and they were usually babied by the folks that owned them. The engines wear extremely well because they had superior engineering to other GM divisions and had a much higher nickel content. One of the coolest things about them is you get huge big block power inexpensively and for 50 lbs over a SBC if you get an aluminum intake.
      As for the Impala/Monte set up...I've seen them rear ended/rolled/Tboned in junkyards and bodyshops already for well under $10K. They're out there.
      Washington, MO
      LOL that is awesome! Good luck with it.
      About your wheels.. Think of them as blocks when you draw them to get the right shape/angle.
      Anway.. even a 305 would make that thing haul.
      Southern Indiana
      Ro already, ooppss Professor Velrev, already did the caddy install in a Chevette, gone fire wall, th400 8 in Ford and somthing like wheels up low 12s at the drags with "stock' engine (75 Caddy 500, 70 closed chamber heads, cam lifters springs and intake and it was smokin the hides.
      I still like the 4.3 idea or even a 3.1,3.4,3.5 60 degree engine from a newer front drive, set it up with custom built 4l60E , paddle shifter, it wouldnt take super large rubber to stick like glue. since your opening the wheel wells you wouldnt even have to have expensive tires as ricer/tuner tires(ie smaller) would fit much better.
