      Feb 2007
      Chicago
      High Output Turbos & Manual Box
      Hi Guys,
      I'm building a hi-output (750-1100hp) mopar sb w/turbo. The car is a 71 Cuda (3200#) & will be used for drag, road & open road racing. The majority would be drag (because of local) but not specificaly set up for drag racing. I REALLY want to go w/ a 5 or 6spd manual but am afraid of too much stress on the drivetrain (cf driveshaft, strange 9")& the trans itself. It will be a single turbo & come on a little soft, so I'm thinking that will help with the lauch & durability.
      Are any of you guys running high tq. set-ups w/ a manual & beating the crap out of them. Will they survive?
      Any suggestions on trans (tko vs. T-56), builders, clutch set-ups, links etc. would be greatly appretiated.
      thanks,
      scotty H.
      Aug 2006
      go with built 727 ...it is a torq monster...nothing will handle the torque better--especially for what you are going to do with it.
      Riverside CA.
      Quote Originally Posted by KillerWolf
      thanks,
      scotty H.
      Scotty, If you are still looking, here's what works for me.
      The vidio in my sig was a 1.38 60' , I launch at 6K.
      G-force GF5R trans, rated @ 1300hp, hundreds of ratios to chose from,
      http://www.gforcetransmissions.com/tran_gf5r.asp
      Advanced clutches, Sportsman 7" 2 disc. This is mostly a drag clutch, but can be adjusted for street driving. Adjustment takes about 15min.
      http://www.advancedclutches.com/products.htm
      post back if you need more info.
      ---Bill.
      68 Camaro, 383, F-1 Procharger, G-force 5 speed, 9", Best 1/4 et 9.40 @142.5, 1.33 60'
      http://www.youtube.com/watch?v=O68yeamBteI
      Milwaukee WI.
      Mine is surviving. I run a Viper T56 with about 850 rwhp.
      Twin Turbo Ls1 '71 Chevelle
      93 octane 1000 hp street car!!
