      Bay Area
      Lowered 83 Malibu Wagon
      I've got a problem that is rather basic but still has me wondering. I put in some Hotchkis lowering springs in my wagon and for some reason the front sits higher than the rear by about an inch or less. I sat the stock springs side by side and they were all the same height. I then took out the Hotchkis springs and sat them side by side and they were the same height. I've R&R them twice and still the same results. They sit like they should but there is still a rake. Does the front suspension just need to settle or is there something I'm missing? I also replaced the shocks and that hasn't helped. My only reasonable solution would be to put airshocks in the rear. Any suggestions?
      Jose (Joe)
      1963 Nova SS Convertible
      1978 Malibu LT1/4L60E
      1978 Malibu Stock
      2007 Harley Dyna SB
      Nov 2002
      state of confusion
      Your wagon is probably a little heavier in the rear than the sedan model that the springs were almost certainly designed for. You could perhaps fabricate a pair of rear spring upper seat extensions that are positively located by the existing contour and locate the upper pigtails in a similar fashion.
      Norm
      Gone but not forgotten dep't:
      I have a suggestion. Check out your local parts store for a spring catalog. Unless you know a counterperson is competant, don't let them help you. Bring a pad/pencil for notetaking and in the back of the catalog you will have all the various types of front/rear springs listed by part number and their corresponding specs. Once you know what style your spring is after looking it up, go to the section in the back that lists all of your types of springs. For the rear, you need to stick with two pigtail ends. Now, of all the various info to be gleaned from the book, pay attention to the following:
      !.) load rate
      2.)free/installed height
      3.)wire diameter
      You can really pick a good choice among the OEM replacement springs if you know what to look for, and you need to be able to think outside of the box a little. For example, know that if you are reading two springs specs that show the same load rate but one has a thicker wire diameter, it will effectively make the rear a tad higher-all other things being equal. You want to find a spring that will give you a higher load rate but at a lower installed height. So now you have to realize maybe you need to find a spring that has fewer coils, thicker wire diameter and a lower free height. You won't always find exactly what you want but once you find the specs for your stock springs, you know what to direction to go after that in terms of what to look for in a spring. No matter what, it's all still going to be trial/error-but you need actual info for comparisons. I did a BBC install in a 1978 Monte Carlo once and after a lot of searching for just the right front spring, I found one that was pretty much exactly what my numbers showed I needed...and it came in as front springs from a 1967 Cadillac DeVille-it was the same spring style, slightly lower installed height than my Monte by about 1.5", and bigger wire diameter. It was perfect for me in that situation.
      [email protected]
      Marshall , MO
      You could also cut the front spring to get it to sit just right.
      Brad Shepard
      69 Malibu
      Marshall, MO
      PA.
      Hotchkis recomends an old school air bag setup (which they sell) in addition to their springs when used on station wagons for the same reason Norm mentioned. You could also modify the rear springs seats. Airshocks are a poor solution to any problem. Moog 5413 are `67 Chevelle wagon springs that should give you the rate (167lb/in) and a very slight drop from stock height when installed in a G body but Moog and most other stock replacement springs have been a real crap shoot for the last few years so you may or may not get what you need out of them. The last option would be to go to springs with an open coil on one end and SpeedWay motors adj. threaded spring seats. That takes a bit of welding and fab work but you`d have adj. rear ride height. We have this set up on one of our G bodys and it works pretty slick. Mark SC&C
      Rolla, MO.
      f-body rear spring along with the f-body upper spring insulators...you can trim them to whatever height you want since they are open on the top and the insulator has a small hole in the center that matches the g-body upper spring perch.....that my take on the idea anyway
      I'm running GW f-body rear springs
      Matt
      1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
      Washington, MO
      I wouldn't do the air bags... makes for a poor ride IMO.
