    Results 1 to 8 of 8
    Thread: Carb help
      Papillion, NE
      Well you are probably a little low, I sure wouldnt go lower,
      Holley float level is as much a tuning aid as any other part of the carb. Those instructions are merely a place that everyone can get their motor running
      As you raise or lower, its tougher or easier for the siphon to pull through each circuit. Its most prevalent on the transition circuit.
      That doesnt mean that IS your problem, however, although I wouldnt venture to guess that your primaries with jet extensions could be coming uncovered at acceleration and maybe causing half of your problem overall
      Next time you play with it, I recommend raising the float level front an back about 2-3 flats of the nut if that makes sense. It should readily, but not crazily come out of the hole when you take the plug out.
      However, I have had cars with fussy intermediate circuits that I even go higher than that. Like I said, just another tuning tool.
      I personally dont like jet extensions unless there is no other choice. I would pull them out of there myself, especially on the front
      70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
      71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
      13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
