      Stockholm,SWEDEN
      quick steering on a 72 nova?
      Hello!
      I´m thinkin of upgrading the powersteering on my nova 72, and got some questions which I hope to find some answers to
      first, can i use a quickratio gearbox from a 4th gen nova or camaro on my 3rd gen? which parts do i need to change if so?
      tiltcolumn from a 4th gen in my car? will it fit?
      Jonas
      Central CA USA
      Yes, but you need to use either a late pump and have hoses made, or use an early pump with stock hoses and use adapters on the box. The box has O ring type hose ports, the early are 45 deg inverted flare.
      You need a new coupler to fit the PS box, Lee Manufacturing has them, the fittings too.
      I've got info and parts list on my web page, nova is the same as early camaro.
      Stockholm,SWEDEN
      Thanx alot! I´ll check your site for more info, which I have to say is filled with great info:3gears: ...I´ve used many of your front and rear suspension info allready, so hopefully i end up with a nova that will do allright on the tracks!
