      Scottsdale, AZ
      Do I need a wider Rear?
      If I were to do the DSE tri-4 bar rear suspension and also do the mini-tubs sould the rear end be replaced with a wider that stock unit. I currently have a 12 bolt all re done and was thinking about going to the 9 inch that currie has if I can sell my 12 bolt. If I were to make the change over oviously i'd have to know for sure if I were doing the DSE rear suspension, but should I order the housing wider for the offset wheels?
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      May 2003
      Austin, TX
      when people switch to wheels with a deep offset, to get the dished look, they usually end up narrowing the rear end, i think it is something like 2" per side usually.
      Apr 2004
      Yuba City, CA (bout 1/2 hour north of Sacramento)
      C Dog let me know what u want for your 12 bolt..what gears are in it?
      J.T.
      May 2002
      Northern California
      you did not say what back space your rims are, if you doing a tub job with a new housing, it would be ideal to set it up so you can use with 0 offset rims ie: 18x12 = 6" backspace
      in this case you would have to get a narrowed rear end.It really depends on the look you want.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      CA
      Zero offset on 12" rim (12" bead width) equals roughly 6.5" BS, depending on the lip width.
      Typical semi-floaters (ie, Ford 9", Dana44, etc) and c-clip HSG has axle face to bearing centerline offset of 2.5~3". For best axle and bearing longevity, wheel centerline should be close to the neck of axle. This means slight positive offset, like 8.5" BS on 12" rims, for example.
      On the other hand, shallow BS rims will save some unsprung mass (narrower axle). Think of current SCCA T/A cars. Flat-face rims up front to cut down scrub radius, and dished wheels rear for lighter unsprung mass. Keep in mind those cars use full floater axles with huge axle snouts, that can withstand the extra stress from negative offset rims.
      Probably good street axles and bearings would tolerate neutral offset rims, but I wouldn't even consider using wheels with large negative offset on street cars that get driven hard.
      Narrowing independent front and independent rear suspension to fit dished wheels just for the sake of aesthetics is dumb.
      The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
      Signed,
      A driver who laps Big Willow at 1:42.6 in a 134hp BMW - and I am still considered mediocre.
      May 2002
      Northern California
      your right Katz I forgot about about the lip.
