      Dart Iron Eagle question
      hi,
      anyone here with Dart Iron Eagle Platinum heads with 200cc intake runners and 64cc ?
      i have this heads on my El-Camino engine:
      GM Performance Parts 350cui block 12486041
      DART IRON EAGLE Platinum heads 200cc intake runners
      Professional Products Air-gap High-rise Intake
      EDELBROCK AVS THUNDER 800cfm re-jeted
      FEL-PRO 1094 head gaskets 0.015"
      COMP CAMS XE274
      COMP CAMS Valve springs, retainers, valvelocks
      COMP CAMS Push rods chrome-moly
      CLOYES TRUE Roller Timing Set
      MSD 6T ignition system
      MSD Billet Distributor
      MSD 8,5mm spark plug wire-set
      Splitfire spark plugs
      Flow-kooler waterpump
      Meeling Hi-volume oil-pump
      engine-oil cooler HD
      Fluidampr Harmonic balancer
      RAM-AIR BOX
      last summer i testet the Camino on dyno: 330rwhp
      thats ok for me, but now i have a problem
      the Oldsmobile from my wife is ready and i feel now, the engine in the Olds runs better ....and FASTER !
      i build this engine for the olds with the same block, camshaft and so on. the one and only difference are the Vortec heads.
      any idea ?
      greets
      Klaus
