      Sep 2007
      Chicago
      monoblade throttle bodies
      I own a 1991 GMC Syclone I am running more then 14lbs of boost with 202 heads, everything ported and polished, and a 503 lift cam. I am considering upgrading to a bigger turbo and a bigger fuel everything in doing so I am concerned that my 52mm throttle body will limit my about of boost, I was looking at the monblade asm throttle body and I have read quite a few threads on the pros and cons of the monoblade, does anyone have any ideas on what my best option would be? Should I just go to the duel 58mm? Or would the monoblade be my best option?
      Sep 2007
      Edmonton, Alberta
      If you are going to be using your stock intake, wich I guess you will be, then a monoblade is really your only choice. Many argue in favor of the crossectional area of the dual blade as opposed to the mono saying that you will get smoother part throtle opperation out of the dual blade design. But that is all very subjective and really of no major concern for force fed engines. I'm not to terribly familiar with the syclone intakes but im almost possitive that a 90mm monoblade will fit with some grinding to match the hole in the intake to the t.b. Visit the guys at http://www.s10forum.com and one of the guys with a syclone will more than likely point you in the right direction.
      Hope I was of some help.
      cheers bbcc
