    Results 1 to 20 of 51
      Jan 2007
      Twinsburg OH
      GM 600 Steering Box Kits
      If you want to upgrade the OEM power steering box or convert to a Power Steering Box on your 1964-’95 RWD GM PASSENGER CAR but don't want to go with a rack and pinion?
      No problem, we are now offering the best steering box ever offered by GM- Delphi. The GM “600 series” Power Steering Boxes were originally designed for NASCAR.
      The GM 600 Box is slightly lighter than other power steering boxes and is available in several different ratios for optimal steering performance depending on the vehicle; 12:1, 14:1, and 16:1 ratios are available for this steering box. These Power Steering Boxes will accommodate heavier rides with ease as well. We offer this box alone or with the necessary rag-joint (coupler) and adapter fittings that enable you to use your existing sttering hoses.
      We also offer the correct GM Type II/TC power steering pump that is internally adjusted for the proper fluid flow and pressure to give you the very best “Box & Pump” steering available.
      We are currently offering a 10% discount & FREE SHIPPPING (to lower 48 states only) for a period of 60 days on anything we sell.
      So if you are interested in improving the steering of your ride take a look at our website and use the discount code: PT-10
