Results 1 to 10 of 10
Run-Out Vs. TIR; bellhousing alignment
i need to align my scattershield. i test fit it with straight dowels. the indicator dial has a total delta of 0.020 where i need to shift my bellhousing toward 10:30 position. offset pins come in .007, .014, & .021.
i need an offset of .010 to line up the centre of the circle from shield & centre of the crankshaft. if i use the .007, i can get my indicator dial to a total delta of .006, but the centre of the circle will be within .003.
Tremec requires run-out to be within '.005'. i thought run-out was the same as TIR (total indicator reading), but if that is the case, then i can't get within tolerance - there wouldn't be any offset dowels available! so.... for anyone that was actually in an engineering classroom.... is 'Run-Out' the difference between the centre of the circles, or is it synonymous with TIR?
i ASSume that run-out is actually difference in the centre of the circles because of the choices of dowels - as long as .005 is a standard tolerance?
by the way... i know, i know.... i can enlarge the existing holes and weld on washers, but this is a question of definitions rather than what my options are.
on another note.... i had a heck of a time pulling out my straight dowels with the usual vice grips method. so, i drilled a hole all the way through the dowel, tapped for a zerk fitting, and pumped grease through to the back of the dowel and pushed it out. first time i've used that method, worked great!
09-17-2007 #2
Starting The Transformation
- Aug 2004
- 210
Pitch the offset dowels. PITA. Get a Browell bellhousing alignment tool (~$140). It attaches to the crankshaft. There is a sleeve that will slide onto this tool. This sleeve has an ID of the tool, and an OD of the registration hole in your bellhousing (-.005"). Drill the dowel holes in your bellhousing to a larger size so the bellhousing will slide around some. Get a set of .5" long sleeves with an ID that will snugly fit the straight dowels. Bolt the tool to the crank. Lay the bellhousing on the back of the block. Slide the sleeve down the tool and into the registration hole of the bellhousing. It is now aligned. Place the 2, .5" long sleeves over the dowels and weld them to the bellhousing. Done.
09-17-2007 #3i seen that Browell tool. very slick.
i read about it here: http://www.camaros.org/bellhousings.shtml
in that article, they say that the OD of the sleeve is .0025 smaller than the ID of the register. that tolerance would be .0025 difference of the centers of the circles, or .005 TIR. so, if that's the case, the tolerance of that tool seems tighter than the options of the offset pins (if you were to use them). furthers the confusion.
anyhow, seems that i should just get it as close as i can and be happy with it, but i really am curious about the definition of run-out vs. TIR.
thx for the suggestion.
09-17-2007 #4
