    Thread: LT1 to LS1 T56
      Jul 2007
      Wisconsin
      LT1 to LS1 T56
      I have a line on a complete LT1 with T56 for $600. I have a LQ9 that I will be putting in my Nova and want to have the T56 behind it. Would it be cheaper to buy this and convert it or to keep looking for a LS1 style T56?
      I know it would need a new input shaft. While it is apart what other upgrades would be smart? and what other pieces need to be replaced?
      Any input from you guys would sure help.
      Dunwoody, GA
      I'd buy the LT1 unit, then sell it for a profit to buy an LS unit. Don't forget the LT1 uses a pull style clutch and a 153 tooth flywheel. The LS uses a push style and a 168 tooth flywheel.
      Trey
      ~ Jon Hammond
      Austin, TX
      If you wanted to convert an LT1 to LS1 you'd have to swap the input shaft and the front plate. However, you'd have to find those parts at a reasonable price to make the swap worth it. Not to mention needing a different bellhousing & flywheel.
      Sounds like buying the LT1, cleaning it up, and reselling is your best bet unless you can find a trashed, cheap LS1 version w/ all the other necessary components
      Morgan
      '87 Monte SS
