Thread: C4 suspension install
09-15-2007 #1
I am installing C4 corvette suspension in my 71 Dart and have some questions I hope someone can help with. Should the lower control arm mounts be level from front to back or should the front be higher? I am planning on using all stock mounting points based on the stock subframe. Should I change any of the mounting points from factory? Are the lower control arms to be level from the ball joint to the frame mount at ride height?
please help
Nate
Nate Kauffman
"She sips nitro with phase 4 heads, 600 horsepower through the wheels, shes meanness set to music and the bitch was born to run." Mad Max
