Results 1 to 11 of 11
09-13-2007 #1
Starting The Transformation
- Feb 2007
- 327
Can I get some help with this intermittant Holley problem please?
Hi,
I have a Holley pro-jection fuel only 2 barrel system. Been working great for at least a year but lately sometimes when I turn on the ignition key you won't hear the fuel pump and the fuel pressure guage will show it didn't pump up but if you open the throttle you can hear the injectors buzz even though they're not squirting anything. I can shut off the ignition and come back hours later sometimes and the car will run fine. I get the feeling it wouldn't be loose wires to the pump because it has never stopped running on bumpy roads or anywhere while driving. Only after it has been sitting a while. Anyone got any idea's? Thanks
09-13-2007 #2
- Feb 2007
- 327
Oh yeah, maybe it would help if I mentioned I'm not using a relay for the fuel pump, I just wired the pump directly to the computer, I only set the fuel pressure at 15 psi though so not a huge load. Is the ecm supposed to be able to handle this? Could it be I burned out the electronics in the ecm bad enough that it only sometimes works? Or is that impossible? Been running like that fine at least a year.
09-13-2007 #3
- May 2006
- 110
I would see if the wire is getting power when you turn the key. If so see what your amp draw is? Holley says to use a relay over 10amps.
09-13-2007 #4
- Feb 2007
- 327
Thanks 69Bbird. How do I figure out what my amp draw is? I'm using the regular holley pump at 15 psi, Could this be too much? Or maybe could they draw more amperage as they get old?
Originally Posted by 69Bbird
09-14-2007 #5amps = voltage divided by resistance, and most cheap multimeters will give you voltage and resistance
09-16-2007 #6
