      NJ
      c5 brake bolt size
      does anybody know what size bolt holds the caliper abutment bracket to the spindle for an ATS spindle. also what are they torqued to.
      thanks,
      -Tom
      TuoCo, CA
      I used 12.9 M14x45mm item 91290A727 from mcmaster-carr.
      tyler said to use a 40mm but the 45 worked fine.
      These are socket head cap screws that take a 12mm allen. I paid almost $30 locally for an SK 3/8 drive.
      Steve
      Check it Out Here
      Yes, M14 is the bolt. I torque mine to 85 ft-lbs with anti-sieze for thread lube.
      jp
      ​John Parsons
      Oregon
      M14x2 X 45mm HHCS, Class 10.9 torqued to 115-125 ft-lb.
      I always run a hardened washer under the head for better load distribution and no marring/embedding. If you choose to use socket head cap screws, a cheaper method than buying a dedicated socket is to buy an L-wrench and cut an inch off of long end with a friction cutoff saw...then just use a standard socket.
      TuoCo, CA
      ditto on the washer. i used blue lock tite.
      Steve
      Check it Out Here
