Results 1 to 15 of 15
Thread: Fuel system question
09-07-2007 #1
I'm getting ready to install my fuel tank and will have to figure out how I'm going to run the fuel lines.
I am running EFI, my new tank is a modified stock tank by Rock Valley, with an in-tank pump.
The top of the tank has what appear to be 3/8" female fittings for vent, feed, and return.
I picked up some 1/2" aluminum line that I was planning on running for the return. (I had always read that the return line should be larger to prevent any pressure in the line which could throw off the regulator. I've seen that some people here disagree with that.)
My current plan is to make a bracket near the tank that the lines from the engine compartment will mount to, and then the flex lines from the tank will mount to the fittings on the bracket.
The bracket will probably hold the fuel filter as well.
Has anyone got any feedback, suggestions or recommendations?
TIA!
09-08-2007 #2
- Sep 2004
- Kettering, OH
- 537
For that pump, 3/8" should be plenty. Al may not be a good line material choice on the street though. Btw, I posted a bunch of EFI sizing info that I've collected here: http://john.my67.net/efi.htm The pump you have is 255 l/hr.
09-10-2007 #3I would not plan on running aluminum for the pressure line, but I was thinking that it might be okay as a return line. Am I wrong?
09-10-2007 #4
- Sep 2004
- Kettering, OH
- 537
The problem with thin wall aluminum tubing is that it is prone to fatique cracking. It also burns through easy potentially turning a small fire into a big one.
09-11-2007 #5Okay then. I briefly thought about perhaps using it for the vent line, but I guess the fire thing is still going to be an issue.
Looks like there really isn't a place for this tubing on a street car, is there?
09-11-2007 #6
- Aug 2004
- 582
I'm not sure I would get too worked up about a fire hazard, personally. Look beneath your newer cars; their fuel lines are plastic. Good planning can also prevent most fatigue concerns, but if you've never bent aluminum before you may want to learn on something other than your fuel system.
09-11-2007 #7
