      HELP-Mcleod adjustable pivot ball question
      I am in the middle of my TKO swap, and the instructions for the adjustment of the clutch fork are a bit sketchy.
      It says with your finger in the linkage dimple on the clutch fork, and the TO bearing touching the pressure plate there should be 5-7 degrees of forward angle.
      How do I measure 5-7 degrees? You really cant see much in there.
      Also, when you try to tighten the lock nut on the adjuster, the part that screws into the bellhousing unscrews?
      Are you smellin what I'm steppin in?
      http://www.fquick.com/ertoys
      Windham, NH
      I just went through this. I "eye-balled" it.
      I took out a protractor to kinda see what a 5-7 degree angle looked like (the main objective is to have a slight angle toward the engine so that the pivot has maximum leverage). I then set the pivot ball out far enough so that the fork looked like a 5-7 degree angle (tilted just toward the engine).
      You want to achieve the slight angle toward the engine while not having pressure on the fingers of the clutch.
      If you want to actually measure the angle, one way you may be able to do it is to continue the angle of the fork with a magnetic steel ruler so that it sticks out through the opening in the bellhousing. Intersect that line with the flat of the bellhousing and that will give you your angle.
      As for the pivot ball, there is a slot in the back of it. Stick a screwdriver in it. You will most likely have to cut about an inch or so off of the ajustable pivot ball. Be sure to put the slot back in the end of the bolt (I did this with a cutoff wheel).
      There are some most likely unhelpful pics here:
      http://www.69taposer.citymax.com/page/page/4654059.htm
      (looks like I didn't take many pics of the fork or pivot ball).
      Phil
      Build site: www.73camarobuild.com
      Business: www.classiccarblasting.com
      Like us on Facebook!
      Thank you very much for your reply! It really helped me. The install went well (overall). The car is a dream on the highway now.
      However, I am a little concerned about clutch chatter-new disc and pressure plate. Maybe its me but it feels like I have a little chatter.
      Is this normal?
      some high performance clutches will chatter... what are you running?
      also did you make sure to clean the machined surface on the fly wheel with brake cleaner?
      Quote Originally Posted by RobM
      I am running the 10.5" Centerforce LMC disk with the dual friction pressure plate.
      Yes, I absolutely cleaned the pressure plate and the flywheel surfaces with brakecleaner.
