      May 2006
      Gas gauge not working
      I'm having a problem with my gas gauge. The gauge works fine with the tank out of the car but when I strap it in the gauge gets stuck at 1/4 tank. I am not pinching the wire when I put the tank in. Any thoughts on this would be great I've had my tank in and out about 10 times. I had a fuel cell in before so this is a new problem.
      Southern Indiana
      Ok so this is simple, double check and make sure that when you ground your gas guage wire the guage operates.
      when you install the tank make sure you ground the tank module(the thing that has the sneder on it) to the car.
      Also make sure your sender wire isnt broke somewhere inside the harness near the tank.
      Its very simple the sender simply has a variable reostat (variable resistor in line with the guage and ground.) that regulates the voltage introduced by the dash cluster voltage regualtor.
      Good Luck
      Lee Abel
      AFTERMARKET PERFORMANCE
      May 2006
      oopps lever hitting baffle.
