Thread: Spal Controller and Taurus Fan
08-24-2007 #1
New to Pro-Touring
- Aug 2007
- 4
Hi,
I'm installing a taurus fan and decided to go with the spal pwm controller. I see that the fan is a two speed fron the plug. Should I just hook up the controller to the high speed wire?
John
08-25-2007 #2Yes, just use the outermost +12v terminal. This will give you the full range of speed from the fan to work with. Mark VIII fans can be wired in the same fashion too.
[email protected]
08-27-2007 #3I have been running the same combo for 2 months with good results. Run a 40 Amp fuse for the fan.
08-27-2007 #4Since its a 2 speed fan, you can hook up a 3 way switch to it cant you? one for high and low.
1993 Camaro Z28
2001 Camaro Z28
1969 Camaro
