      Salem N.H.
      LOKAR E Brake Handle Mount
      Does anybody have pictures of this handle mount? Ordered from lokar through Jegs for willwoos brakes on a 69 camaro. I almost started working this tonight but thought maybe somone has better ideas to rig this up. I believe it came with cables from a small truck . The most confusing part to me is where to mount the brake handle. Small maybe 10 inch crome handle. Looks like it bolts from under car and handle comes through the floor?
      Kevin
      69 Camaro 454
      HD soft Tail
      72 Telecaster
      Dec 2002
      Lost Wages, Nevada
      ATS makes a bracket that mounts the Lokar handle to the trans tunnel... its the same one Stielow used in a few of his builds.
      Give Tyler a call... he'll give you the skinny on the whole gig.
      Kevin,
      With my 3 link rear suspension, my cables come into the car up under the rear seat. I made an aluminum box that sits on top of the driveshaft tunnel that houses the lever and adjustment mechanism.
      jp
      ​John Parsons
      Salem N.H.
      Thanks Guys Sounds like the hole only needs to be enough to get the cables through. Much better ideas!
      kevin
      69 Camaro 454
      HD soft Tail
      72 Telecaster
