    Results 1 to 13 of 13
    Thread: no oil pressure
      livermore ca
      no oil pressure
      iam not getting any oil pueresser on my 95 lt1 i took the fitting out of the block were the gague fitting gose squerted some oil down there till it was full and still nothing then did it agaen but did not put the fitting back in then crancked it over and oil was squirting out so i thought i fixed it put the fitting back in still no oil pueresser whats wrong?? need help A.S.A.P
      PS: i primed the pump already
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      Aug 2001
      Wilton, CA. (Sacramento)
      you do have the stub shaft mounted under the intake that drives the oil pump, right? If you do then the next thing I'd verify is that the gauge works.
      Jody
      livermore ca
      the little plactice pice that has a gear on it?
      Quote Originally Posted by camcojb
      Jody
      65ss chevelle
      63ss nova
      3:73
      Aug 2001
      Quote Originally Posted by lt1chevelle
      yes, looks like the bottom of a distributor.
      Jody
      livermore ca
      yes i have that installed
      65ss chevelle
      63ss nova
      3:73
      Aug 2001
      what kind of gauge (electric or mechanical)? Are you starting it to check for pressure? Do you have a remote oil filter?
