    Results 1 to 17 of 17
    Thread: How much boost?
      CT
      How much boost?
      How much boost can stock shortblock take and be reliable?
      John
      Dec 2002
      Lost Wages, Nevada
      Without "O" ringing the block... ?? I'd say about 6 to be anywhere near reliable.
      Dunwoody, GA
      Are we talking truck motor, be it a 5.3 or 6.0 or are we talking car motor LS1/2/6?
      Trey
      ~ Jon Hammond
      CT
      Car ls6.
      John
      Dunwoody, GA
      6-7psi properly intercooled and you should be fine. Of course it will depend on just how hard you drive the car. I have a customer with an 03 vette and we did his Pro-Charger when he had maybe 1500 miles on the odo. I rarely hear from him as he is very busy and has had no issues. Last time I talked with him he was over 20k and loving it. He runs it hard from time to time as well. He loves running Ferrari's on the interstates around ATL. They never expect him to keep up.
      Trey
      ~ Jon Hammond
      Dec 2002
      Lost Wages, Nevada
      Quote Originally Posted by WS6
      That's kinda surprising... Ferrari's are not all that fast to begin with.
      Dunwoody, GA
      haha this is on the interstate from a roll. Besides, his car was built before the Stage 2 system was ever available, so his car only makes 450rwhp/400 ftlbs. Now my customer with the 04 Z06 and Stage 2 Pro-Charger makes 540 at the wheels and has 3.90 gears. His first and second gear are nearly useless under boost, but on the interstate the 3.90s are very fun.
      Trey
      ~ Jon Hammond
      CT
      With a stick shift; do you think a gross calculation can be based on 15% loss?
      John
      Aug 2005
      Asheville, NC
      I have been told to replace the head bolts if you go past 7psi.
      Milwaukee WI.
      With head bolts and 6.0 gaskets you can do 10 psi with a low (6,000) redline. Forged rods, pistons and studs will do 25+ psi.
      Twin Turbo Ls1 '71 Chevelle
      93 octane 1000 hp street car!!
      Dunwoody, GA
      Head bolts are cheap insurance. My numbers were based on using the same heads the engine came with. Nitro is right though about using 6.0 heads on an LS6. I completely forgot about going that route.
      Trey
      ~ Jon Hammond
      Dunwoody, GA
      Quote Originally Posted by ponjohn
      John
      Yes, but you might as well figure 18-20% so you can be surprised and feel better when you go over that number.
      Trey
      ~ Jon Hammond
      Santa Barbara, Ca
      LQ9 heads
      That's what I did, swapped the LS6 heads for a set of cnc'd LQ9 6.0 heads. For those who don't already know, the LQ9 head is almost identical to the LS6 head but it has 71 or 72cc combustion chambers that will make your compression ratio a little more boost friendly.
      As a side note, there are guys running 12-14 psi on stock LS1 shortblocks with good results. Are these motors going to last forever? Probably not, but it can be done with careful tuning. I'm looking to run 10 psi on mine, but am having some belt slip issues right now that are keeping me at 6 psi.
      Andy
      We typically see stock short block failure somewhere in the 550-600RWHP area. Turbo cars seem to be on the higher end of the spectrum, and blower cars on the bottom end.
      That being said, we have had them fail below 550, and had them last over 600 too
      CT
      Fail in the sense that the block fails?
      John
      Block and crank rarely fail before a piston/ringland or rod will.
      Milwaukee WI.
      It is almost always #7 piston lands that go first, then the rods. Change both out with forged units and you will have a virtually bulletproof motor.
