Thread: thermostat temp and switch temp
This may have been answered but I could n't find anything in the posts. I am running a 496 big block chevy in a 69 camaro. I have a howe alum. radiator, spal dual fans with a 185* temp switch, edelbrock water pump and 180* stat.
My question is how do you determine the correct thermostat temp and fan switch temp that will work together to achieve maximum cooling?
Right now I have the 185 switch that turns on at 185 and turns off at 165, but my engine never gets that cool so the fans are running almolst constantly.
08-13-2007 #2
- Sep 2004
- 28
You should try a programmable fan control module.
I recommend the Spal pwm. It has low and high temp setpoints. The low point uses Pulse Width Modulation on the primary fan for variable speed control to minimize noise and fuel economy. The fan gets progressively faster as the temp approaches the high temp setpoint.
An additional relay will need to added to control operation of the secondary fan which will be enabled when the high setpoint is reached.
-Steve
08-14-2007 #3You need to change the fan switch. If your thermostat opens/closes at 180 then the fans cannot possibly cool it to 165.
What you should have is the fans turning on at 205 and off at 185.
08-14-2007 #4I agree. The thermostat is the minimum coolant temperature. Also, I wouldn't go lower than 180.
Originally Posted by GetMore
1970 Corvette Convertible
Fuel Injected, Supercharged 406 SB Chevy
08-15-2007 #5Thanks guys, I have ordered a new switch. It makes sense, just wanted to see what opinions were ot there.
