      turn signal led install
      I'm putting in the Covan Classics gauge cluster in my 74 Camaro - I had put in some $1.99 LED's from Radio Shack( 12 v 1.5 amp, I think ) - they lasted about 2 mins !! Should of known the 22 + gauge wire was too small. Where can I get some small stock style LED's for the dash. Also I spliced from the dash connector ( light blue wire - right turn but got nothing from the dark blue - left turn when I put a test light ot it). Any help would be greatly appreciated.
      CT
      I used the Indicator Lamps from painless, which I ordered from jegs..
      They were about $7.00 each I think..
      Bryan, 69 nova LS3 w/T56 Ridetech subframe
      Southern Indiana
      Well I hate to tell you but you have to wire a resistor inline of the diodes or they will blow up, period.
      Got nothing to do with 22 guage wire.
      also you can get LED replacements for 194s at most autoparts stores.
      Sorry guys ... seem like I jumped the gun. Traced the light blue wire ( left turn) to the switch( column) and was getting the power but at the led - nothing ...turns out it was a poorly soldered connector. I love happy endings !! However I'm not using an inline diode ... the guys at Painless said it takes very little power to run them .... where would I get the diode ? What purpose does it function ? Doesn't LED stand for Light Emitting Diode ? Thanks, again.
      Melbourne, FL
      Quote Originally Posted by nx74ls6
      Yes LED stands for Light Emitting Diode. But you need a resistor to cut the voltage or they burn up real fast. Go to this site. It really helps with installing LEDS. They also sell LEDS with resistors already built in. I'm using those for indicator lights on the Covan dash for my 67 'Bird. Also replaced most interior lights and indicator lights on my 97 GTP with LEDS. The interior LEDS really made a difference.
      http://www.superbrightleds.com/
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Fontana, CA
      I have the same Radio Shack LEDs in my 69 and they work perfectly. Mine do have a resistor built in. Not sure what the issue was with the ones you got.
      What did you do for the right indicator? There are 3 wires for the right signal and 2 for the left (at least in mine, depends on what type of flasher you use). 2 of the 3 for the right side are the same color (dark Blue IIRC).
      Nick R.
      The right turn indicator on my 74 is a single dark blue, I pulled it off before the OEM gauge cluster harness- tapped right into it . After fixing the poor connection issue on the LT turn indicator now everything seems fine.
      I know the factory shares a common ground with the entire circuit on the gauge cluster but auto meter said I'd get funky results with the gauges if I didn't seperate the grounds of the bulbs and gauges. The question is should I also seperate the grounds of the turn signal switches ( left ground and right ground) ? I did a preliminary check and the everything worked great but when I put the headlights on the left turn signal just stayed on - the right works fine with lights on or off. Any opinions ? This caveman could use some. Could it be that the other dark blue wire has a purpose? I checked it and got nothing at any point.
