      Oct 2005
      New Washington, IN
      Which headers mufflers?
      I have very limited clearence under my car, and am trying to figure out what to do. Motor is a BBC with very large cam and very high compression. Mostly drag car, but will occansionaly drive on the street, cruizes, etc.
      Just need to get it quiet enough to drive on the street some.
      Should I go with,
      http://www.jegs.com/webapp/wcs/store...44688_-1_10265
      3 disk
      or
      http://www.jegs.com/webapp/wcs/store...50014_-1_11535
      or
      http://www.jegs.com/webapp/wcs/store...48205_-1_10265
      Headers are 2 1/8" with 3.5" collector, Ed Quays, with slip fit.
      __________________
      1971 Camaro 427 in waiting
      1988 C1500 Daily Driver
      livermore ca
      i would think the last one would quiet it down for the street the last 2 i dont think do much i think my friends dad run one of those inserts and its still loud ass hell
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      Delaware, OH
      I've tried the car chemistry inserts as well as the dynatech cones and neither quieted the exhaust one bit, they just changed the tone. I've also tried collector mufflers similar to the Dynomax units and they did help some (maybe a 20% reduction in sound), but it was still WAY too loud to drive on the street. Plus the collector mufflers leak badly around the collector joints, especially of you have any pipe down stream causing back pressure.
      The only way I was able to quiet down my 572 was with a full exhaust system (3" x-pipe dynomax system exiting directly behind the rear wheels). I even tried 4" flowthrough mufflers after the collector with 4" turn-downs, but it rattled my teeth and alerted every cop in three counties.
      Personally I would try the dynomax.
      Oct 2005
      New Washington, IN
      It does not have to be quiet.
      Our 55 has 2 3" spin tech pro street mufflers with turn downs, it is loud but driveable. I am looking for the same for this car.
      Delaware, OH
      Quote Originally Posted by Johnny Blaze
      Then I would also go with the DynoMax. Those with some turn-downs (pointed at the ground) will also help.
      Oct 2005
      New Washington, IN
      Ever tried pointing the turndowns towards each other? I remember reading this somewhere, it said that they 'cancel eash other out' and quietens it somewhat.
      Delaware, OH
      I've heard the same thing, but never have tried it.
