      Welland, Canada
      Moser 12 bolt fit
      Does anyone know if these are exactly the same size as stock front to back with a 1350 yoke?
      In other words will the driveshaft have to be shortened at all if I'm running a 12 bolt already?
      Dean
      69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
      ST U/LCA's-GW Del-a-lum's-Lee p/s
      May 2002
      Northern California
      ...there is usually enough play in the trans yolk shaft to take up the slack. but my swag is no, it should go right in.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Aug 2003
      Sold tons of them, they are direct bolt in replacemnts, unless you specify otherwise.
      Welland, Canada
      Frank, will Moser weld the perches on to give the pinion a specified up or down angle?
      Will I still be able to use my Baer brakes?
      Dean
