Thread: stuck hydrobooster
New to Pro-Touring
- Sep 2006
- the Netherlands
- 22
stuck hydrobooster
I've been busy for two evenings now trying to locate a problem with a hydroboost brake system.
A friend of mine bought a '70 1/2 camaro wich is totally restored.
Beatiful car ,......but it also had the stock mastercilinder without booster.
So we updated it to a hydroboost system from a late 90's astro van,complete with mastercilinder.
At first it performed flawlessly,with good braking,but after some 100 miles he complained about the brakes not getting loose after braking.
I've driven the car two days ago and it feels like some residual pressure.
After braking it takes a second or two to come loose,it just like your still braking a little.
There's no difference in normal or hard braking when it occurs.
We've taken of the master and cleaned it,put another (slighly heavier)spring in the hydroboost to help the rod inside get back a little,but no succes.
Braking with your right foot and immediatly helping it upwards with your left helps a little,but not as expected.
The only thing not used from the astro van was the prop valve,but we still have it.
Any comments on this problem?
thanks,Louis
