    Results 1 to 10 of 10
      Apr 2007
      Colorado
      Lokar E-Brake cable install????
      Does anyone have pictures of a Lokar e-brake cable install for their internal e-brake Wilwoods? I would like to see how others routed/mounted the cables to the under carriage. Thanks in advance
      Jason
      Aug 2006
      I have a Lokar e-brake setup on our 69 Firebird. We have Ford explorer discs which have parking brake internal to the rotor. I think that Wilwood has similar design. Anyway, here's a pic of how we set-up/mounted it.
      Apr 2007
      Colorado
      Thanks for the help! That is similar to how I am going to do it.
      Walton, NY
      I'm wondering if I should buy a Lokar kit as well. I'm using blazer backing plates and a 4th-gen lever, so I'm not quite sure yet how this will work.
      I'm using a Lokar hand brake with Wilwood brakes. I find the setup marginal because the effort seems pretty high compared to OEM hand brakes.
      jp
      ​John Parsons
      Salem N.H.
      Lokar brake Handle
      John Do You have a oicture or description of instalation of the hand brake lever? Looks like lokar mounts from under car and has the handle sticking through the floor? ???? I am confused and don't want to cut the floor incorrectly. Installing the cables / handle to willwoods on friday . Thanks for any help
      Kevin
      69 Camaro 454
      HD soft Tail
      72 Telecaster
      Dec 2002
      Lost Wages, Nevada
      ATS makes a bracket just for the Lokar handle. Give Tyler a call and he'll give you the low down on it.
      Kevin,
      Chicane is right: give Tyler a call. He can set you up. I can't recommend my method ... too time-consuming.
      jp
      ​John Parsons
      Salem N.H.
      Tyler
      Is Tyler a company?
      69 Camaro 454
      HD soft Tail
      72 Telecaster
      Huntington Beach, CA
      Quote Originally Posted by Whistle Pig
      Is Tyler a company?
      No, original comment was:
      Quote Originally Posted by chicane67
      Tyler is the name of the person to talk to at the company ATS. They are a sponsor and you can find their add to the right.
