      Jun 2006
      g-body drop spindles
      I read on this forum the warning about drop spindles on camaro , the a-arm can touch the wheel .
      on a 81 monte-carlo , can I have the same problem ? if I can have the same problem , what wheel dimention and offset I can installed and what I don 't can ?
      Farmington Hills, MI
      Yes you can have that on a G-Body. If you run a big inch wheel you should not have a problem (17-20). The steering arm is even closer though.
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
      Jun 2006
      tanks for the information GBODYGMACHINE !
      PA.
      The basic answer is to just stay away from traditional drop spindles altogether. They cause a number of problems and can hinder rather than help performance. The only exception is a non traditional drop spindle like the AFX aluminum spindles which have a much more modest 7/8" drop. Mark SC&C
