Thread: can someone help
07-20-2007 #1
can someone help
i have a 67 camaro with a fuel injected 383 stroker.the fuel injection is controlled by acell dfi gen7...i have my lm1 setup along with the dfi to control air fuel ratio...about 2 weeks ago i was driving and the car started to have a real bad lean backfire...i confirmed this by hooking up my laptop and sure enough it was showing lean...anyway i went ahead and changed the fuel pressure regulator thinking that was it to no evail...now its real rich at idle and when i step on the gas in neutral it still goes real lean....does anyone have any suggestions as to what could be the problem??i was thinking of changing the fuel filter...also i checked the ohms on the injectors and they are all fine...one other thing when i start the car from a dead cold the fuel pressure stays steady but after it warms up the needle on my guage begins to jump around...just for the record i changed nothing in any of my maps in the dfi...again,any ideas or suggestions are welcomed...
mike
