Thread: Valve adjustment
07-20-2007 #1
New to Pro-Touring
- Dec 2005
- Salem N.H.
- 44
Valve adjustment
I just broke in the cam on chevy 454 solid lifter lunati cam.
The question... I don't know what specific cam I have as I just moved and lost the cam ticket. Seems like the valves may be a little tight? I checked clearance before start up and it was around .030 thousandths ??? The engine has no lifter / valve train noise but after 5 to 10 seconds stalls out . No vacuem leaks, carbs is close enough to idle? Does anybody have a suggestion on what to adjust these valves at I believe the lift was around .550 No idea what the duration is?
TIA Kevin
69 Camaro 454
HD soft Tail
72 Telecaster
07-20-2007 #2
- Jul 2007
- 4
do you remember what cam you bought like the part number cause you can go on line and probably find out what it has to be set at.
07-20-2007 #3
New to Pro-Touring
- Dec 2005
- Salem N.H.
- 44
Lash found
Thanks Frank, I called Jegs and they had the part number they sold me 18 months ago and also gave the valve lash..
Kevin
69 Camaro 454
HD soft Tail
72 Telecaster
