Thread: Update to BB compression issues
07-18-2007 #1
- Jan 2005
- 38
Well first off all intake pushrods bent on both heads. Pulled off heads and all intake valves were hitting pistons. Two bent valves and stuck open thus proving the no compression theory. So at first i thought maybe the deck height is to low on the heads i bought. Some one else suggested valves were too tight or the timing is way off. Could it be that the cam is off. I swore i adjusted the valves correctly three times. Dont know if i should get valves fixed and try again or buy new heads.
07-20-2007 #2
- Feb 2007
- 164
If it's all cylinders buy 2 valves and set them up again. Check installed height's. Piston height & cam lift. Was the head gasket too thin? If you can get it right on one cylinder you should be able to get it right on 8.
07-22-2007 #3make sure of the timing chain. quick reference is dot to dot. but check the crankshaft keyway. it should be in the 2 oclock position. not straightup.
what is the cam installed at? how big are the piston domes, how far in the hole is the piston and what size heads/chambers are they?how muck have ben milled off?
07-25-2007 #4
