Thread: BBC oil leak
07-18-2007 #1
- May 2003
- St. Charles, Mo
- 424
BBC oil leak
I've got an anoying oil leak in my BB Chevy. It looks like the oil is coming out of the front seal around the Harmonic balancer or the front of the oil pain gasket. There may be some small oil seapage around the front china wall under the intake. It appears to only leak after heavy acceleration runs over 4500 rpm up to 6500 rpm.
I'm thinking it is a crank case pressure problem. Both valve covers have breathers. I do not have a PCV valve in the valve covers. Will the addition of the PCV valve help? I would have put one in already except that it is going to take some fabrication. The vavle covers don't have a hole for the PCV valve and I don't want to add it to the top of the valve cover.
The harmonic balancer is a new fluidamper and the engine is a fresh rebuild so the seals are new. The oil pan gasket is the one piece silicone style gasket.
Dennis
