      Headers hitting Gear box.....help
      I got a new power steering gear from Lee ent. (670 box) and now my Hooker super comp headers (1 3/4 tubes) are hitting the gear. I have SB motor mounts and frame pads in the car I thought some where I read you can put BB mounts or pads in the car and it will move the motor over to the pass side? I can find it now.....has any one had any experance with this? or what options do I have with out getting new headers. (68 nova with 400 SB w/Dart 215 pro one heads, auto)
      Brian
      Fontana, CA
      Beat the headers into submission.
      Lot easier than clearancing the box!
      And yes, the BB pads do move the engine to the pass side.
      Nick R.
      Delaware, OH
      The correct BB "frame" mounts will do the trick. They move the engine/trans forward and to the passenger's side. Had the same problem with my old Hooker Super Comps and after installing the BB frame mounts had 1/4" clearance between the steering box and header tube.
      I think we will try the BB mounts next I am not wanting to beat the headers to clear the box.....I hope they do not move the motor ahead much, I am installing a procharger w/cooler on the car and need every bit of room up front for radiator/cooler.....cant change any thing with out it affecting somthing else (one would think I would of learned that by now) Thanks for the input.
      Brian
      Salem N.H.
      Steering Hose clearance?
      My super comp header is blocking the engine side hose opening . I have beet the header and can live with it but I still havn't gotten the hose to clear. I am trying to make a hose with an imidiate 90 degree turn ?? 69 camaro BB with power steering and BB mounts on the frame. Any suggestions? Is the engine side the pressure or return line?
      Thanks Kevin
      69 Camaro 454
      HD soft Tail
      72 Telecaster
      Benicia CA
      Quote Originally Posted by novaracer
      Brian
      The mounts should move it over and forward about an inch each way. At least it did in the Camaro we did.
      joe
      Joe G
      69 Coupe; ZZ430;TKO 600 5 speed; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Ride Tech Strong Arms and coilovers front; Classic AutoAir AC and power windows now cuz I'm old and lazy!
