      Nov 2004
      Houston.
      C5 conversion snag.
      I started on doing the swap when I ran into a little problem. I've read that the 3rd gen fbody rotors are used for hubs when doing the C5 brakes on B-body spindles. Well I had the 1LE rotors which I turned one down. When I went to bolt the caliper bracket to the custom bracket, it comes 1/4 inch short of bolting up. Then I looked around on the web and the outside hub to mounting surface was 2".
      Example http://www.geocities.com/diels12000/CamaroRotor.jpg
      I measured mine it was 1 3/4".
      When talking about the 3rd gen fbody, I guess they meant the regular rotor?
      Here's some pics so far.
      May 2002
      Northern California
      Yep that would be the regular rotor.
      Pep boys had them for $14 each. bearings are extra. I like wrecking yard units...but you need a core.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Nov 2004
      Houston.
      Well I picked up a rotor on the way home so I'll put it on the lathe soon.
