    Thread: Temp sender?
      westchester county new york
      Temp sender?
      I need to reinstall the sending unit that switches on my fans, should I mount it to the head or the manifold? I have it in the manifold but the fans go on erratically, is the head better?
      Florida
      Did you check the grounds?
      The sender switch is a ground, it grounds the fan circuit to the block and the fans switch on.
      I moved it to the head and cleaned off the thread sealer, it seems to work better now. Maybe the sender did not get hot quick enough in the aluminum manifold.
      Thanks T/A. Do you ever go to the marcus dairy show?
