      Oct 2005
      Olathe, KS
      Will any 4L60e work?
      I bought a 4.8 out of an '03 Silverado. I want an electronic OD tranny, but I'm not going to spring for a 4L80 since this is just a driver. Can I use any 4L60e, or do I specifically need one out of a truck? I know there are some with different bellhousings, and that some are one-piece and some are up to 3 pieces. To make things worse I discovered that the some tailshafts on the truck trannies are longer than others. I just want to pop it into my '64 Impala with the S&P tranny crossmember, shorten the factory DS and mod it for the 4L60 slip yoke, but I only want to do it once. I can pick up a tranny out of a 2000 Camaro locally for cheap and I want to use it if I can.
      -Chris
      '64 Impala Sport Coupe- Slow-Touring project; LR4, 700R4, work in progress
      '66 Corvair Monza Convertible- 110, Powerglide
      '95 Z28- 355 LT1, 76mm turbo, built 4L60E, 12-bolt
      '98 S10 scsb- 4.3 auto
      '00 Corvette coupe- 6-speed
      Fontana, CA
      the 2000 camaro has an LSx engine just like the 4.8. It will work.
      Nick R.
      Dunwoody, GA
      I don't know my trannies that well, but you should be able to use any 4l60E designed to be behind a gen 3 motor. however, which one will fit best for your application I don't know.
      Trey
      ~ Jon Hammond
