    Results 1 to 20 of 29
    Thread: II Much update
      II Much update
      Road Atlanta showed some areas in the car that needed improvement, so I've been a little busy getting the car ready for a Sebring event in August.
      I've swapped springs (200 to 250 in back, 475 to 550 in front), power steering pumps (to a TurnOne Saginaw unit), front wheel bearings (front right had failed), and set the front suspension into track mode. Katz's design has dual modes up front (street and track). Track mode has more camber gain, but also more side scrub.
      I also put in more static camber (1.5 degrees).
      I just got back from a low speed test (never went faster than 70 mph). Turn in is explosive. I really need to pay attention, or I change lanes and drive on sidewalks. It's almost twitchy. I gotta check the toe settings ...
      The brakes are rock solid and feel great. I think I finally have them sorted out. The problem was wheel bearing play causing knockback. I was blaming my pedal linkage, but that wasn't the case.
      Steering is the same as before, so we'll see how it holds up this weekend at the MSCC autoX event. That's where I'll find out if I need a ps cooler.
      jp
      ​John Parsons
      Fontana, CA
      Sounds awesome John. Glad to hear the brakes are in check now. Let us know how she does.
      BTW, which compound are you running on your pads?
      Nick R.
      Aug 2002
      Waleska Ga.
      If i show up can i ride shot gun again! LOL!!
      David Sloan
      Boston MA
      At Road ATL, what sort of tire temps are you seeing? I'm interested to hear how a relatively light car deals with the big tires? Good to hear the car is sorting well. Keep at it.
      1967 #s RS
      Auburn, WA
      Quote Originally Posted by wendell
      I'm curious too. Art's Vette was pretty tough to put some decent heat into the tires. Never have gotten them fully warmed up to date.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      at Road ATL, what sort of tire temps are you seeing?
      I don't know. I didn't have a tire pyrometer to check the temps. All I can say is the outside edges of both front tires was warmer than the inside edge, as checked the instant I brought the car to a stop and jumped out. They had time to cool a bit, but not much.
      The outside edge was "comfortable" to the touch. I didn't need to pull my hand away to keep the skin from burning. The brakes, on the other hand, were way too hot to touch.
      Does that help?
      Oh, and and the car isn't very relatively light. :( It weighs 3300 lbs with me in it.
      jp
      ps. Still checking on brake pads. They are the default pads on the Wilwood kits. I haven't changed them.
      ​John Parsons
      Jan 2000
      Thousand Oaks California
      Quote Originally Posted by d touring
      I want video if you do!
      Larry Callahan
      Sebring ought to "shake things up!" Never been there, but I don't need to have, just watch the 12 hour race and you can see how violent the bumps are. I am sure you probably will, but I'd bring four jackstands and give the car a thorough nut-bolt between rounds, at minimum on the critical areas. This said, knowing that your car is still new, an ounce of prevention.....
      Nice to see you enjoying it and playing around with it, learning what it responds to in terms of changes, etc. I seem to recall that you had an issue with the construction of the rack brackets, I think I read that by accident it ended up in the wrong fore-aft location, which would affect Ackerman. Knowing Katz, he probably designed for a good amount of Ackerman, in which case you can easily get away with straight ahead-to- slight toe-in, and have terrific turn-in. With reduced Akcerman, many folks resort to a slight toe-out, which can help initial turn-in, but can also make the car very, very twitchy.
      Very interested to see the results of the power steering pump, etc, I'll be in this boat here very soon too (i.e. LS based motor, no experience with the compatible p/s pumps), though it'll be with a box in lieu of that gorgeous Woodward rack unit you run. I'd really like to be able to adapt a KRC pump, have you looked into that possiblity?
      Thumbs up, cool to see the progress!!!
      Mark
      I'm running Wilwood Q compound pads. Just an ordinary street style pad.
      Mark, I've heard about the bumpy track at Sebring. A local guy with hundreds of laps there says the bumpy part is only in the "legacy" sections. Anyway, it really takes good shock setup to keep from skipping around on those areas, yet still have proper valving for the rest of the track. All I know to do is to set my QA1s 2 clicks softer. I'll let folks know how that worked out.
      I didn't have any setup problems with my rack placement. I did weld the front crossmember 1 inch too far forward. A slight redesign of the LCA and using a thinner steel rack adapter instead of the thicker aluminum allowed me to regain 1/4". But my wheelbase is 110.75 inches, whereas stock Novas come in at 110. So Ackerman wasn't affected (as far as I know).
      I found 1/8" toe out felt really good in the street setting. The car feels like there is more than that now. I'm gonna check it out tonight.
      As far as power steering pumps go, I think the KRC is based on a Saginaw casting. As is the C5 pump. So you can use the KRC with the C5 accessory drive brackets, or use a Wegner/ATS/VintageAir. All are based on that basic Saginaw casting.
      If this TurnOne pump still has issues, then I'll add a cooler. If I still have issues, I'll swap over to a KRC and remote reservoir.
      jp
      ​John Parsons
      Sure enough: I was driving around with 3/8" toe out. That'll make for some quick turn in.
      jp
      ​John Parsons
      Feb 2006
      SoCal
      MAN!!! I can't wait to get to your stage!!!
      John
      ***Under Construction***
      Build Update Link:
      Central CA USA
      Good luck John! I think you will need the PS cooler sooner or later...
      David
      St. Augustine, FL
      John- Sebring in August? Need any help??
      Andrew Petty
      Andrew,
      I'd love to have some help. It's on the 25th. Right now I'm 5th on the waiting list for the Novice class. They tell me I should make it in, but I won't know for sure until the week before.
      jp
      ​John Parsons
      St. Augustine, FL
      Andrew,
      jp
      As of right now it shouldnt be too hard to change my schedual and get off of work. I'd have no problem doing whatever I can to help out.
      Andrew Petty
      Auburn, WA
      Those are OK if you want minimal brake dust, but that's about it. I swapped mine out for a J pad. MUCH better!!
      Matt Jones
      Mechanical Engineer
      I couldn't care less about brake dust. I'll do the same. Thanks!
      jp
      ​John Parsons
      Damn. No J pads available for my calipers (Wilwood type 7416 front, type 7112 back). How does BP-20 stack up against the J?
      jp
      ​John Parsons
      Fontana, CA
      I just put BP-20s on and they are GREAT (compared to BP-10) and are much more fade resistant. Not as good as an A compound or a Perterfield R-4, but those are race compounds which destroy rotors during street driving. I keep my R-4 pads for the track. If porterfield had called me back I would have tried the R-4S pad as it is supposedly comparable to if not better than the BP-20.
      Nick R.
      Auburn, WA
      jp
      Oh, you have the thin pads. Neither the Q or BP-10/20 pads have anywhere near the friction of the J pad. Seeing as that J's are not available for your calipers, go with the H pad. The downside is they are more aggressive on the rotors than the street compounds. IMO, it's worth it.
      Matt Jones
      Mechanical Engineer
