Results 1 to 20 of 22
07-07-2007 #1
Cheap 2nd gen firebird front end triangulation
I was on a mustang site where they sold braces to triangulate the opening in the core support in front of the radiator. It was supposed to increase front end rigidity.
Since I have solid bushings on my core support I thought something similar may help. I also thought it might make a pretty big difference since it would be so far forward and tall. In looking at the front of the core support, I found that the upper AC condensor mounts would catch the top outside corners and the center brace behind the nose would get the lower, center.
I grabbed my old fender braces and they fit perfectly. I put the non slotted ends at the top AC condensor mount location using grade 8 5/16 bolts. Even with the battery and all the AC lines in place, it was pretty easy to get to both sides of the core support. The lower slotted end of the brace just barely caught the hole at the bottom of the center brace that is already present for the spoiler mount. The left side thus went pretty quick.
For the right side I had to drill a 5/16 hole in the center brace opposite the factory hole. With a right angle drill this wasn't too difficult. Without one I don't think you could do it with the center brace on the car.
Bottom line, it took me about 30 minutes to bolt everything up including drilling the hole.
I went for a drive and the difference was pretty significant. The decrease in rattle was immediately noticed as was the lack of the roof popping over driveway cuts.
At speeds over 30 mph turn in was drastically improved. The car felt really solid.
If you have some extra late 2nd gen firebird/TA fender braces and some time, it is a pretty easy upgrade with little weight penalty. I had updated to the aluminum braces sold by WFO leaving me the extra braces.
07-07-2007 #2I'm ac condensor-less, so could you post some shots so I can see if I can figure out a way to make this work on a non-ac car?
07-07-2007 #3It shouldn't matter as the core support should be the same. Look just outside the top, upper corners of the radiator opening. You should find a 5/16 hole, speed nut, or something to take a 5/16 body bolt. Mine were just 5/16 holes but who knows if that is original.
What you are looking for is the holes that mount the AC condensor in front of the radiator. I'll see if I can get some pics tomorrow, but it might be too tight for my camera. You can just barely see the supports.
It might be the easiest to find the holes on the motor side. They should be right under the top plate about 1/2 inch from the top of the tank.
07-08-2007 #4
- Aug 2004
- Dunwoody, GA
- 4,983
