Thread: Cage question?
07-02-2007 #1
Cage question?
I know i should level out the car and all prior to installing the cage(6 point in an 80 camaro).I have the sub frame off the shell.Do i need to bolt the frame back on and set the frame and shell on stands to do the cage install.
Thanks in advance
Eric
07-02-2007 #2The general rule for this should be the same as installing weld in subframe connectors ( or probably any SF connectors) Re install the front clip and get the wheels back on the ground prior to any installation. Otherwise the shell may be flexed during install and then when you DO put the car back on the ground you may be more apt to see cracks in the welds or an inability to align the car due to a "twist" in the shell.
Anyone with more experience ( I know there are a lot of you here) please make sure I'm not leading Eric down the wrong path.
Good luck!
-MikeMike M
67 Camaro, big plans, empty wallet!!
07-03-2007 #3you need to reinstall the sub frame and instll your sub frame connectors 1st,then install a cage,
07-05-2007 #4
New to Pro-Touring
- Feb 2006
- 67
agreed, do it with everything on before you weld in the cage.
