    Results 1 to 10 of 10
      Near Dayton, OH
      Lug nut thread engagement
      How much thread engagement is considered safe? I have a set of TTII Classic wheels, Kore3 billet aluminum hubs w/ stock length 12mmx1.5 studs and C5 rotors. I know the rotors throw everything off by about a .25" or so and have heard people say longer studs are necessary but I have at least 10-12 full lug nut revolutions before even touching the wheel.
      Would this be considered okay?
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
      Feb 2006
      Brampton, Ontario, CANADA !!
      10 - 12 turns should be fine. Generally the mininum requirement for thread engagement is equal to the diameter of the stud. So at least half an inch of thread engagement should be present.
      cheers
      Ed N.
      Ed Nicholson
      73 VW Super Beetle "Sports Bug"
      95 Taurus SHO 5-speed -- new open-track beater
      I checked. 10 revolutions of lugnut on 12x1.5 stud equals about 0.750 (16 mm) of thread engagement.
      You'll be fine.
      jp
      ​John Parsons
      Mountain View, CA
      Basic aviation fastener rule of thumb: There shall be a minimum of 2-3 threads exposed when the nut is torqued in place.
      ....and JP is right.
      True T.
      My blog
      Near Dayton, OH
      Cool. Thanks for the help!
      Sep 2001
      Accord, NY
      Quote Originally Posted by Damn True
      Is that for visual inspection needs? Or stress points?
      68 camaro - SOLD
      Mountain View, CA
      Inspection is a part of it. Makes it easier for a crewman to visually confirm that a fastener is correctly in place. All bolts are sized such that 2-3 threads will protrude. If you see more, the bolt is stretched or the wrong size, if you see too few the fastener is backing off.
      There is also, and IMO this is the more important point, an issue with the distribution of load. If all 20 or so threads on the inside of a nut are engaged onto the bolt the load is distributed as equally as possible and each thread is seeing as little individual load as possible. If there are not 2-3 threads exposed then the top 2-3 threads on the nut are engaged with the tapered portion of the threads on the bolt reducing the surface area in contact with the nut.
      Same is true of castelated nuts and self locking fasteners like jet-nuts.
      True T.
      My blog
      Fontana, CA
      NHRA and some sanctioning bodies require open ended nuts with protrusion of the bolt to ensure adequate load.
      Nick R.
      Very true. My lugnuts are close-ended, and I worry about passing tech every time. So far, no problems.
      jp
      ​John Parsons
      Newbury Park, CA
      As noted above 2 threads minimum of exposed thread when using a nut. In reality +90% of the tension load is held in the first three threads of the nut.
      For blind holes a minimum of 1.5X thread diameter of engagement is considered normal.
