    Results 1 to 20 of 22
    Thread: C5 irs question
      C5 irs question
      Has anyone used a C5 IRS with a different rear end? I'm talking about using an older corvette or new GTO differential with the rest of the C5 suspension.
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Aug 2005
      Patterson, NY
      I'm not sure, but I think the "rear" on the C5 is a transaxle. I believe the suspension bolts to the transaxle, so it's not a simple swap.
      You are talking about using the arms and the driveshafts, but fabricating everything else.
      So, to answer your question, I don't think anyone has done it.
      Its not really a transaxle. Its a transmission attached directly to the differential. The lower arms are supported by a cradle under the differential. The upper arms are attached to the frame rails. It looks like a fairly simple swap to change out the differential. This would allow a standard driveshaft setup instead of using the trans in the rear.
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Auburn, WA
      Quote Originally Posted by 70 LS1
      I believe 21st Century already makes an adapter for just that...
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Orlando, Fl
      Quote Originally Posted by silver69camaro
      That they do:
      http://www.21stcenturystreetmachines...php?item=C5IRS
      They only list an application for 1st gen camaros at this time, but I am sure it could be adapted to other models.
      Quote Originally Posted by dipren443
      That they do:
      Yeah, I talked with them. That might be an option, but I was thinking of using a different differential other than C5 like a C3 diff. Just seeing if anyone has tried it.
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Feb 2006
      SoCal
      At one point I was thinking of using a 'stang 8.8! If you're going to use an older or different diff your going to have to modify the half shafts anyways! Like this:
      John
      ***Under Construction***
      Build Update Link:
      Quote Originally Posted by novanutcase
      John
      I just saw the build pics in your build up post. Do you think there would be enough room in your car to use buckets in the rear on either side of the trans?
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Los Angeles
      John
      Nice plate...send it home?
      Feb 2006
      SoCal
      Yup! Even though Rodger, the owner of Ironworks, wants me to eliminate the rear seat I have insisted that we keep it. From Transaxle to rear door panel it measures 25". I figure with the tunnel and upholstery on both sides I should end up with at least 22" which is more than enough to accomodate a normal sized person!
      John
      Build Update Link:
      Atlanta, GA
      I believe someone was using a GTO diff on LS1tech but GTOs have had some diff problems. I would go with the Ford 8.8 if you're fabbing everything up. The factory C5 diff. IMO is not strong enough to warrant adapting into a traditional diff.
      You may also want to looking into using a Nissan diff. The R230 is a ~9" ring and is supposed to be very tough. Hybribz.org would be the place to start researching those rear ends. Ls1tech has had some discussion as well.
      Lamar
      00 C5 hardtop H&C 436 rwhp with an 04 Z06 Suspension
      70 Chevelle SS396
      Rolla, MO
      The body shop owner where I get my work done just swapped a IRS rear from a Nissan 350 Z into his cuda. I crawled under the car and he had to weld up four mounts. It looked pretty slick.
      I know he said for his application the width was spot on and the bolt pattern was already correct for a mopar. He's running a warmed over 360 with it and 18 inch tires.
      May 2002
      Northern California
      ...and you didn't take pictures?? we'd love to see it.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2007
      I'm using a Ford Expedition rear differential with corvette c5 suspension on an irs. The hardest part is getting the correct upper control arm location. Mounting the diff has been straight forward and sits in the aluminum cradle ok.
      Eastern Virginia
      Quote Originally Posted by novanutcase View Post
      John
      That is sweet. Where did you get the dims of the mount points of the control arms?
      Scot
      86 Monte SS
      Atlanta GA
      anyone know what 21st century is asking for those rear kits?
      Nov 2007
      Vancouver, WA
      My dad used a Ford 9" center section from Dutchman back in 2000...
      1970 Dodge "E-Tikit" Challenger
      Feb 2007
      A software program, Suspension Analyser, has the stock c5 suspension attachment points already loaded. A free sample program is offered with the data in it.
      Atlanta GA
      Feb 2006
      SoCal
      It's pretty pricey! I remember getting a quote from them but I don't remember what it was now. It was definitely in the thousands!
      John
      Build Update Link:
